| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | I need longer studs on my intake manifold to adapt to the carburetor I want to use. I need to put a spacer under the carburetor to clear the throttle linkage. I believe I need about 2 inch studs with 3/8 threads. Will the studs come out of the manifold? Are these available? Thanks. Pete
Chevy Pete
| | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | Yes, the studs just screw into the manifold. Sometimes they're very stubborn, so use a good penetrating oil like KROIL or PB Blaster, some heat from a torch, and either a stud remover or tightly double-nut the studs and use a socket and a long handled ratchet or maybe an impact wrench to back them out. Dorman makes a good assortment of studs to choose from- - - -you'll probably find the thread in the manifold will be coarse, and the top will be a fine thread. For instance, 3/8-16 in the manifold, and 3/8-24 holding the carburetor on. Also try Fastenal for custom-length studs. Jerry
| | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | Thanks Jerry. I was able to get the studs out. Now on quest to find new ones. Pete
Chevy Pete
| | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | As a last resort you could take a long 3/8-16 bolt, cut off the head, and cut a 3/8-24 thread onto the unthreaded portion of the shank. Then trim off both ends to get the thread lengths you need. I do that on a lathe, but if you're careful with an adjustable die the same thing could be done in a vise. Jerry
