9 members (lumbersawyer, Jon G, MickeyP, Joe H, 55shaker, 3B, 68ironhead, VEW, Pre '68 Dave),
56
Mod | | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I have an aftermarket sender that won't let the gauge go to empty. The lowest ohm reading I can obtain is 3.5 ohms, any ideas how to correct this or will I need to try to find a sender that will read 0 ohms at empty. If so any ideas where to find one? Thanks in advance, Scott | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I bent the float arm on mine so it is correct on empty and don't worry about the full reading. I know it's full when the pump nozzle shuts off if I fill it up.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The gauge has an electrical tolerance. The sender has an electrical tolerance. The gauge has a mechanical tolerance. The sender has a mechanical tolerance. The only way to do a gas gauge and sender is to calibrate them together on the bench as close as possible.
This calibration was done, explained and videoed by DADS50.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | The float is not the issue the gauge sender needs to read 0 ohms for the gauge to read empty, which is what I am trying to accomplish. I know when it's full but would like empty to be empty not almost showing a 1/4 of a tank. I could not find the tech tip for DADS50 and would like to check it out . Thanks, Scott | | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Accuracy of these fuel level systems is far from perfect, even with properly working original components.
What does your gauge read if you have the fuel sending unit out of the tank and the float in the lowest position? Make sure you ground the sending unit for this test. It does not seem right that 3.5 ohms is giving a 1/4 tank reading in a 0 to 30 ohm system.
What does the gauge read if you ground the wire coming from the gauge to the sending unit? That should represent 0 ohms and will be the lowest that the gauge will read. Try to ground the gauge very close to the gauge terminal for the sending unit connection behind the dash. Then try this test at the end of the wire at the sending unit at the tank. There could be some resistance in the connectors or that wire.
I assume that your gauge reads full if you disconnect the sending unit wire.
Rusty
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | If I ground the wire at the sender the gauge goes all the way to empty, thus eliminating all connections and resistance from the sender. I have checked all the connections on the sender itself and gone directly to the empty side of the rheostat on the sender, the lowest reading I get is 3.5 ohms. The gauge may be a little below 1/4 but well above empty. As stated before the sender is aftermarket supposedly for this application. Obviously not of good quality. Can anyone guide me to the article from DADS50 on bench calibration of the two components?
| | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | The primary variable left is to determine if the float is at the lowest limit of travel when it is installed in the tank and the resistance at the position.
What resistance does the sending unit read when it it installed in the tank and the tank is empty?
What does the gauge read when you have the sending unit out of the tank and you let the float drop as far as it can go?
I agree with the suggestion to look at the position of the wiper on the coil.
Rusty
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I tried all that, I went to the lowest portion of the rheostat bypassing the wiper, the rheostat where it makes connection with the wire on the sender reads 3.5 ohms and there is no change thru the riveted connections to the post where the wire connects. I am going to try a different brand and if I can't get a "0" ohm reading at empty I guess I will have to live with it. Anything above 0 ohms results in a reading above empty.. The Vendor I can't say I seem to have lost that invoice, the brand is Bob Drake, #C-9275 (It does not appear to be available on their website any longer). | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The only Bob Drake sender for 1941 pick up is THIS. For a Ford. 10 ohms full, 100 ohm empty. If you can't trace it back to what you bought from them, then you have NO IDEA what you have and what the specs are. You are using 0-30 ohms because you searched and found out what a real Chevy sender does. Stick with places like THIS. These are the types of Vendors we use. They sell Chevy Truck Parts only. Buy this one and you will be OK as long as your gauge is a correct 0-30 ohm compatible one. Don't use goofy companies where you can't even find what you bought on their website. Stay away from a company that has a Blue Ford Oval as their logo. They are Ford people. This is what you get when you search "Chevy sender". Out of stock. No mention of year. No ohmage spec. Different part number. You will be back on track soon. Keep the faith.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I purchased a sender from one of the Chevy truck specialists and got another 0 to 30 ohm sender that was actually a 0 to 27 ohm sender and now the gauge reads empty as it should, but it won't go all the way to full. I can live with that! Too bad we can't buy any aftermarket parts that aren't junk! Thanks again Scott | | | | | Joined: Mar 2014 Posts: 4,509 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,509 | Sorry to have missed this. I've posted this answer possibly 30 times here. The only sender I've found which measures 0 and 30 and is constructed so that it will last is sold by an eBay seller with the ID renbusan. Good luck. Most of the sending units out there are not worth buying.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
