| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Hello, per attached pic the Standard wheel for a 1965 C10 was 15" and 17.5 were optional. The wheels on my 65 measure 16.5". What do I have?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Jun 2020 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2020 Posts: 37 | Are you physically measuring it or does it say 16.5" on the tire?
If you're physically measuring it it lip on the outside of the rim will give you an extra inch or so.
If it says it on the tire, you, my friend, have a different wheel than stock! | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Ok I'm measuring it. So I have the standard 15" like the table says. Thanks for clearing that up
