3 members (Guitplayer, Danielbolt, Hotrod Lincoln), 79 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
Junior Member
Junior Member
well guys i got my 3x1 intake and it came with 2 larger RP rochesters. and i have 2 smaller B rochesters. either way i gotta buy one carb now my question is do i run all B's or all RP's which one is better??? or easier to set up for tri power???
and i'm using what i got so no strombergs suggestions please. on a limited budget here
[img]http://i121.photobucket.com/albums/o235/marcelo54/intake001.jpg[/img]
[img]http://i121.photobucket.com/albums/o235/marcelo54/intake004.jpg[/img]
[img]http://i121.photobucket.com/albums/o235/marcelo54/intake007.jpg[/img]
The two marching Rochester carbs are later models than the other one. They will all work together, but don't look as good. Carb King doesn't like Rochesters and has good luck with Carters. you might like them better. Try contacting him for good advice.
I'd say go with the early style with manual choke on the center carb. Don't hook up the chokes on the 2 outboard carbs, you won't need them.
I will say that I go along with Carb King. I don't care much for the Rochester either. Seen too many of them either have cracked float bowls or warped bases. Or both like the one that was on mine. Carters are OK, as long as they're matched. Been ther, done that. Got mismatched carbs from the remanufacturer (one was a FORD carb). Now running matched Holley 1904s, IH application (GMC used them too), very happy with them.
Bill Burmeister
I have an extra Carb just like your first one for sale....email me at [email protected]
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
Junior Member
Junior Member
i'm in miami, 80-100 degree weather all year long so we dont need to use chokes down here. Never have a problem starting carbed cars.
so the 2 on the left are later models?? i take it they are a bit better than the older one then???
so i should go with the 2 one the left and get a 3rd to match?!?!
thanks guys
and who is carb king?
Whatever you go with, they need to all be matched- all the same jets, power valve oriface, springs, accelerator pumps, and vacuum ports. Otherwise they will fight you and you will get mixture problems between the cylinders. I would sell the ones you have and get three that you know match.
Paint & Body Shop moderator
