5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
Hello Everyone,
I am looking for some guidance. I have a recent purchase of a 1951 3100 with original 216, 6 volt system.
The truck has not been driven all year due to some fuel issues. I had disconnected the battery while replacing the fuel tank.
Upon reinstalling the battery, I realized that I had not taken notice if it was connected Positive ground or negative ground when I had removed it.
I know these vehicles were originally positive ground, but I believe it may have been changed to negative ground (not sure)
Anyway, the battery was dead, so I had it recharged, and I am ready to reinstall it. I have heard that one has to polarize the regulator before
connecting the battery. Is this true and, if so, how do I do it? And can I make it negative ground, if it was not so already?
First, if your truck is a Chevy, as you indicated with the 3100 designation, it is a negative ground system. As far as polarizing the voltage regulator, it should not be necessary when just installing a battery. It’s already polarized.🛠
Thank you Justhorsenround. I am glad that's the case.
By the way, I noticed your line at the bottom
I am also retired Thin Blue Liner
God bless.
Sir Searchalot
Sir Searchalot
Martin, I've seen you answer with two little boxes before. What is that?
It could be a mobile emoji not translating to the web site.
Sir Searchalot
Sir Searchalot
So mobile phones don't have access to stovebolt emoji>>> thumbs_up
It’s crossed wrenches or a thumbs up from my iPad.
Sir Searchalot
Sir Searchalot
What's an iPad ? thumbs_up nanner yahoo chug
Insomniac
Insomniac
I believe they are used when you spill gas overboard while refuelling your boat.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
OK I see. I thought it was what Moshe Dayan wore.
' Offline
I too am retired LEO
So one of my favorite old jokes dates back to when the show "fantasy Island" was on TV. Herve Villechaize played the little guy that was famous for the line "De plane, de plane". Anyway, that show made him a very wealthy person and he wanted to share his good fortune. He decided that he would build condos on a scale that made them better serving to "little people". Counters were lower, shower heads lower, etc. He also decided that since little people had a more difficult time finding gainful employment, he would also not charge rent. The complex was very successful.
This thread has gone south!! Let me know if the question was not answered completely.
Another quality post.
Real Trucks Rattle
