2 members (Otto Skorzeny, Charles in CA), 79 guests, and 0 robots.
Topics128,051
Posts1,055,764
#1379152 10/01/2020 5:55 PM
Have a 1955 2nd series pickup with a 265 ci engine ,need help how the clutch return spring is hooked ? It should hook some where around the steering gear box. I maybe missing a bracket or something. Any help ,or picture very much appreciated . Thanks
On my 65, it just goes through a hole in the frame. The hole is drilled up around where the VIN is stamped into the frame.
It's been 20 years since I changed mine over to power steering but I seem to remember that there was a small bracket mounted on one of the bolts on the original steering box.
Fred
Clutch spring attaches to a small ell bracket that's held in place by the oil pan bolt about 4" forward of the bellhousing.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
