3 members (Wayne67vert, Bill Hanlon, Forty9), 86 guests, and 2 robots.
Topics128,042
Posts1,055,518
Members48,424
#137796 04/12/2007 11:18 PM
We just droped in a SB in our 41 1/2t. Just like everyone else exaust clearance problems. Moved the steering box back approx 2". Now everything clears. We used Hooker Block Huggers headers. Can anyone tell me how this will affect the steering and what to do to fix it. Thanks
#137797 04/14/2007 1:09 PM
Can you turn the same distance right to left as before ? If you can still turn against the stops I would say it won't be an issue.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#137798 04/24/2007 4:40 AM
I'm in the middle of a v8 swap for my '42, Sure would like to see some pictures!
#137799 04/24/2007 4:51 AM
I would think that the drag link would now be two inches short and you won't be able to turn much to the left. This may suit you if you are very conservative;-)
#137800 04/25/2007 2:19 PM
Here is a link to some pics of my V8 swap in a 46.
Rick
http://community.webshots.com/user/rlrick
#137801 04/25/2007 7:43 PM
Right on Rick, Nice work.
#137802 05/15/2007 2:38 AM
IF you have move steer box back 2" the drag link needs to be 2" longer
424x4
#137803 05/15/2007 6:30 PM
They are right you have to lengthen the drag link 2”. That is what I originally did. But you have to make sure your steering box is centered. After I redid the interior I ended up upgrading to an adjustable drag link, so I could adjust or center the box / steering. I used a couple of heim joints and tie rod I got from speedway to make my own. The ball ends in the pitman arm and steering arms are the same. So you could use the modern tie rod ends also. They posted a Tech Tip on this a little while ago which you could also check out.
#137804 05/21/2007 3:02 AM
Did you have to shorten the steering column?
#137805 05/21/2007 1:41 PM
If you stay with the original column you would have to shorten it. There are some kits out there for this. I went with an 80's GM column. You just have to find a column with the features you want. The shaft inside the original column is a solid 3/4". The common size they use today. A DD is a 3/4 shaft cut down, a splined shaft is 3/4" or you can pin a 3/4". Originally I put in a collapsible center piece. I modified it later using a borgeson joint. They have some good info on their site on joints and shafting.
