| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 43 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 43 | Hey everyone,
I'm not at this stage yet in my build, but I had a question that I was unable to find anywhere. I love the foot starter concept, but I wasn't sure if it was possible to keep this with an LS swap. I'm looking to put in a LQ4, and I would LOVE to keep the factory ignition with the foot stomp. Has anyone here kept theirs?
Thanks, Bret
1952 Chevy 3100 - currently apart and hogging up the garage.
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | You should just need to re-route the starter solenoid wire through a "stomp" switch from the key switch or wherever your solenoid power is coming from.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I think Hot Rod Lincoln has the number for a tractor starter switch that you can mount the factory stomp starter pad to and once the bellows is in place it's undetectable (PM him). On my Buick (floor foot feed to start) and my Studebaker PU (push clutch pedal down firmly to start) I immediately converted them to key start and did away with two switches and associated wiring.
Evan
| | | | | Joined: Jun 2020 Posts: 43 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 43 | Fantastic news guys! Thanks for the info! I'm glad that it's in the realm of possibilities!
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Try a website such as TSC (Tractor Supply Co.) and search for a starter switch for an N-series Ford tractor. (9N, 3N or 8N) It can be mounted to the floor in the position the foot start linkage would normally occupy, and the original pedal button can be adapted to the switch and covered up by the OEM rubber pedal accordion. It's very hard to tell it from the original mechanical linkage without a close inspection. https://www.tractorsupply.com/tsc/product/tisco-starter-switch-dr405c?cm_vc=-10005Have fun! Jerry
| | | | | Joined: Sep 2010 Posts: 2,331 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,331 | Check out barnfind49 he has the stomp starter on his .there is a video on one of his posts | | | | | Joined: Jun 2020 Posts: 43 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 43 | Try a website such as TSC (Tractor Supply Co.) and search for a starter switch for an N-series Ford tractor. (9N, 3N or 8N) It can be mounted to the floor in the position the foot start linkage would normally occupy, and the original pedal button can be adapted to the switch and covered up by the OEM rubber pedal accordion. It's very hard to tell it from the original mechanical linkage without a close inspection. https://www.tractorsupply.com/tsc/product/tisco-starter-switch-dr405c?cm_vc=-10005Have fun! Jerry Okay I'll check that out for sure. Thanks for that! Check out barnfind49 he has the stomp starter on his .there is a video on one of his posts Checking that out now.
| | | | | Joined: Nov 2004 Posts: 2,421 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,421 | FYI: I bought one last night to have on hand for an upcoming project at the local TSC. They had 2 in stock at $12.99 each. Thanks for the info. Jerry.  John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
