Topics128,180
Posts1,057,146
Members48,463
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
What do you do when you have to charge a 6v battery and all you have is a 12v charger? You use jumper cables to wire two 6v batteries in series and then connect the 12v charger to both of them!!
I have chargers that have a 6V/12V switch. That's the way I'd go.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
I need to find one of those chargers.
Can't you just attach ONE of the charger leads? or maybe plug the charger into a 60 volt ac outlet instead of 120 volts?
220, 221, whatever it takes, eh?
One of my 6V/12V chargers is an Exide one. The other 6V/12V is rather new but it's at our place 500 miles distant. They are both rather new.
Tony,
Save yourself a lot of aggravation and get the right tool for the job.
Walmart has a nice 6/12 volt charger and maintainer for $38 and free delivery to your house.
https://www.walmart.com/ip/70W-Full...n-Car-Motorcycle-Scooter-Lawn/836738554?
HaroldIs a restoration ever finished?
