3 members (2-Ton, Steelonsteel, Donf), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
Here are a few pix of the truck...before I started and now in process.
To post photos, click Use Full Editor at the bottom of the Reply box. Then click Attachment Manager. Then click Select A File. Click on the picture you want, then click Open, then don't forget to click Done.
Did you get your problem fixed regarding not being able to move the truck - clutch, transmission, brakes?
1951 Chevy Panel Truck
Hi Miraclepieco,
I am still doing something wrong...have followed your instructions and also Tiny and it shows 3 photos uploaded, and hit done, but nothing. I will keep trying.
As for the clutch/transmission/brakes, still a mystery. Brakes are free, truck goes forward just fine, but when I try to back up, it jerks and wants to go forward instead...
Lenny
Make sure you are allowing enough time for each photo to load before you hit the done button.
