7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#137631 03/31/2007 5:26 PM
Junior Member
Junior Member
I'm about to put a ZZ3 345hp crate motor in a 1950 3100. It's not going to be drag raced. My question is will the stock rear leaf springs work ok? Will be using a Camaro 10 bolt rear end. Any thoughts or comments?
Thanks -Noman51
#137632 03/31/2007 6:19 PM
Now Norman, even though it won't be "drag raced" are you telling us you're never going to want to stick your foot in it to see what those 345 horses can do? Those ol's springs will support the rear of the truck just fine but are going to want to wind up under all those horses. You really need a 4-link setup in my humble opinion. But, at the very least I would run some traction bars to help those springs stay in one piece!!
#137633 03/31/2007 7:50 PM
Ech what Waldo said. If not 4 link, maybe just an aftermarket rear suspension from TCI or RB'S.
Those stock springs will be a very weak link for that HP.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#137634 03/31/2007 10:46 PM
Waldo is right and my choice after checking the price tag on 4 bolts would be the traction bars. That is something a man of humble means could fab himself. I am doing the same thing on my 51. A 350 sbc with 330 HP with a 700R4 tranny and a 10 bolt Camaro rear with a TCI spring kit. I would recommend anti sways front and rear.
~Jim
#137635 04/01/2007 12:12 AM
Junior Member
Junior Member
Thanks guys for your responces. I know your all correct. Was trying to rationalize. I do have a set of '78 Z28 5 leaf X 2 1/2" springs that are real close to the same length. Would have to fab or buy monting brackets, and use traction bars at the very least. The TCI spring kit that BIG CHEVY 3600 used looks real good also..will check it out.
Thanks again- Norman
#137636 04/01/2007 2:31 PM
Crusty Old Sarge
Crusty Old Sarge
An old racer trick is to fab up some plates that clamp the leafs together in front of the axle. These are about 3/4" wide and are an 1" or so longer than the width of the leafs. Drill holes in the plates that will allow them to be bolted on top and bottom of the springs. 5/16" or 1/4" grade 5 bolts with locking nuts should work. These plates are mounted where each leaf meets, leaving about 3" or so between the end of the leaf. This only needs to be done in front of the axle, and will really tighten up spring pack and act as a traction bar. I have used these on my 56' 210 for years and along with traction bars it realy hooks up, and it's cheap! grin
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
#137637 04/01/2007 2:49 PM
CHEAP? That should settle it!!!
~Jim
#137638 04/01/2007 5:14 PM
Junior Member
Junior Member
you could just fab up a torque arm easily enough, some tubing and some heim joints
#137639 04/01/2007 9:43 PM
Riding in the Passing Lane
Those old truck springs are stout. You are not going to rap them up unless you have some big slicks on there. The tires will spin first. The sway bars are a good idea.
1972 Chevy c10 Cheyenne Super
#137640 04/02/2007 1:27 PM
I got your e_mail.
Modifications are what you can & want to do. I like to leave em stock or just enough to make em safe & driveable. But I,m from the old school. Just don,t get involved in something you can,t handle & it turns out to be a nightmare &/or a money pit.
