| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 4 Junior Member | | Junior Member Joined: Jan 2007 Posts: 4 | I'm about to put a ZZ3 345hp crate motor in a 1950 3100. It's not going to be drag raced. My question is will the stock rear leaf springs work ok? Will be using a Camaro 10 bolt rear end. Any thoughts or comments? Thanks -Noman51 | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Now Norman, even though it won't be "drag raced" are you telling us you're never going to want to stick your foot in it to see what those 345 horses can do? Those ol's springs will support the rear of the truck just fine but are going to want to wind up under all those horses. You really need a 4-link setup in my humble opinion. But, at the very least I would run some traction bars to help those springs stay in one piece!! | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Ech what Waldo said. If not 4 link, maybe just an aftermarket rear suspension from TCI or RB'S. Those stock springs will be a very weak link for that HP. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Waldo is right and my choice after checking the price tag on 4 bolts would be the traction bars. That is something a man of humble means could fab himself. I am doing the same thing on my 51. A 350 sbc with 330 HP with a 700R4 tranny and a 10 bolt Camaro rear with a TCI spring kit. I would recommend anti sways front and rear.
~Jim
| | | | | Joined: Jan 2007 Posts: 4 Junior Member | | Junior Member Joined: Jan 2007 Posts: 4 | Thanks guys for your responces. I know your all correct. Was trying to rationalize. I do have a set of '78 Z28 5 leaf X 2 1/2" springs that are real close to the same length. Would have to fab or buy monting brackets, and use traction bars at the very least. The TCI spring kit that BIG CHEVY 3600 used looks real good also..will check it out. Thanks again- Norman | | | | | Joined: Mar 2007 Posts: 3,388 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,388 | An old racer trick is to fab up some plates that clamp the leafs together in front of the axle. These are about 3/4" wide and are an 1" or so longer than the width of the leafs. Drill holes in the plates that will allow them to be bolted on top and bottom of the springs. 5/16" or 1/4" grade 5 bolts with locking nuts should work. These plates are mounted where each leaf meets, leaving about 3" or so between the end of the leaf. This only needs to be done in front of the axle, and will really tighten up spring pack and act as a traction bar. I have used these on my 56' 210 for years and along with traction bars it realy hooks up, and it's cheap!
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | CHEAP? That should settle it!!!
~Jim
| | | | | Joined: Nov 2006 Posts: 9 Junior Member | | Junior Member Joined: Nov 2006 Posts: 9 | you could just fab up a torque arm easily enough, some tubing and some heim joints | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those old truck springs are stout. You are not going to rap them up unless you have some big slicks on there. The tires will spin first. The sway bars are a good idea. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I got your e_mail. Modifications are what you can & want to do. I like to leave em stock or just enough to make em safe & driveable. But I,m from the old school. Just don,t get involved in something you can,t handle & it turns out to be a nightmare &/or a money pit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
