7 members (cmayna, DadsFirstPickup, 68ironhead, Woodcmiami, Bill Hanlon, truckernix, Otto Skorzeny), 94 guests, and 4 robots.
Topics128,259
Posts1,058,297
Members48,485
I couldn't find anyone that makes a distributor block off plate for a 292 so I made one.
Former Workshop Owner
Great job. thumbs_up Also nice to see you using a 4 jaw chuck. The younger generations don't have the patience or in a lot of instances the ability to dial in a part on a 4 jaw.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Moderator
Moderator
2 Offline
The machine shops I worked in only had four jaw chucks. Nice looking job.
Did you get the o-ring dimensions/tolerances out of a Machinist Bible?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Nice work!
I'm sure you won't have any issues with leaks with those 3 0-rings. Might be a bit of overkill there. wink
Riding in the Passing Lane
I have been working on this stuff for 70 years & have worked on hundreds of 292 engines in fleets of step vans but I can't imagine any use for a "distributor block off plate".
George
1972 Chevy c10 Cheyenne Super
Crusty Old Sarge
Crusty Old Sarge
Very nice work, HRL would call it "Eye Candy" for being polished, but I like it wink
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Actually, I'd call it a very fancy substitute for an expandable rubber freeze plug. It makes as much sense as the rest of that engine does.
LOL!
Crusing in the Passing Lane
There are even linked 4 jaw chucks now, be careful unless you need one.
Ed
George
Sometimes, you want to drive the distributor in a non-standard place.
And sometimes you want to completely do away with a distributor. With a crank trigger ignition you have no gears, chains, or shafts to get slack from wear and unless you twist the crankshaft the timing is always dead on.
Evan
I have an Electromotive direct fire engine management system. I have a billet crank to help with the twist.
I'm no machinist. I just recently bought my lathe. This is the first thing I made from scratch. I just slowly snuck up on it and went off some A/N fittings I have. Certainly over kill but what the heck. I put a larger o ring on top. I will have a vacuum in my crank case.
Nice workshop.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Crusty Old Sarge
Crusty Old Sarge
You didn't just buy a lathe, your bought a very nice lathe... grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Not being a critic, but what drives the oil pump?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
@Whitedog;
He is using a dry sump system. The oil pump(s) are external and belt driven.
SimS
I actually figured out the answer to my question after looking at some other posts. Looks like a not so ordinary 292. I dig it.
"The Fake Truck"
Looks terrific! Nice work.
Mike
