0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | The original 283 in my 58 Spartan 80 was replaced in the 1970s by a former owner. He replaced it with a 1964 283 from a full size car with its (rebuilt) 2 bbl Rochester carb. Runs great, like a sewing machine, but when I head out the driveway, when it is still cool but not cold, with choke off, it sputters and dies, requiring lots of clutch nursing. Once fully warmed up, it is OK. Should I be looking at a 4 bbl as was original.....or maybe I need to keep the choke on halfway for a while longer? I'm starting out in 2nd, not granny gear (New Process 5-spd). I'm not carrying a load. As usual, I am seeking your advice....thanks!
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Forgot to add: I'm trying to start out in hi range (2 spd rear), but seems i should be able to without a loaded truck.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That is EXACTLY what a choke is for, Use it. It is also what a heat riser is for. I.E. cold air. Be sure your air cleaner is BIG and Clean.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Bartamos, thanks! I'll try using the choke more liberally and I'm thinking more about the air cleaner (it's on the smaller side and is not the OEM)
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Make sure the heat riser valve is working properly, and you've got the right gasket under the carburetor. That Rochester 2 barrel has an exhaust passage built into the cast iron throttle body, and if you don't have the right base gasket it keeps the exhaust gas from heating the carb base and the intake manifold properly. The heat riser passages in the intake manifold are also bad about getting plugged up with carbon and restricting or shutting off the heat. Jerry
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Jerry, Thanks for the added insight....that is something else for me to take a closer look at....I think the gasket is right as i remember the punch-outs in it, but it would be easy for me to check. I will also check the heat riser for free movement. I don't know how to clean out the passages or if can be done with manifold installed, but will check my manual or wait for your further guidance....thanks!!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | The passages often clog right at the carb base gasket and can be drilled out. They are only about a half inch deep and then open into bigger passages below that rarely clog. You should be able to blow air in them and hear it at the tailpipe.
The bi-metal spring on the heat riser should lift the weight and close the passage when the engine is cold. It should lower the weight when the engine warms up.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | I used to use a short piece of speedometer cable chucked into a variable-speed drill motor to snake out those passageways- - - -sort of a mini roto-rooter. The carbon deposits just fall into the exhaust ports and get blown into the muffler on the next engine start. Jerry
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I'll add that starting out in 2nd gear-Low while the engine is cold will allow it to warm up faster and help prevent the stumbling. I drive all of my 2-speeds the same way...start in 2nd gear-low and work it up to high gear-low and then flip it into High gear-High range. Mike B  | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | My 283 did not have a heat riser from the factory, check the shop manual - some models have it, some don't. Mine drives the same way, just takes time for the intake and carb to warm up. If the engine loads up with the choke in use then you need to adjust the fast idle to compensate for added fuel when cold.
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Thanks for all the added pointers..... I will check/clean all the parts and adjustments....and maybe 'adjust' my driving methods also!
