3 members (Robert Crandall, 1955 1 Series, 1 invisible), 328 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Does anyone have a measurement of The filler between the running board and box were it curves around the cab corner .what I am looking for is the gap between the cab corner and the curve part of the filler panel.When I got my truck mine were cut for exhaust stacks that came up the side .I purchased a repo filler and it does not fit the curved area for the cab corner needs to be reworked also .thanks Kevin
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
So how far off are the repop running board aprons? I have them and haven't tried fitting them to the truck yet and you're making me nervous. frown
The bed needs to be at the correct height, and the correct distance away from the back of the cab. The running boards need to be positioned correctly also. I doubt if the problem is the aprons.
The original aprons fit but because the previous owner cut the ends off with a torch to allow the exhaust pipe for stacks .They were cut right were they curve around the cab corners. The aftermarket one I have is for the passenger side I got it off eBay so don’t know were it is from but still has sticker on it .the aftermarket one hits the cab corner at the top but is okay by the running board ,so it looks like it has to be cut and reshape to curve around the cab corner.My cab corners are original and the box is original with original fenders .The running boards are gm running boards from different truck .
"The Journey"
Follow in the DITY
Kevin my repop filler panel would be different than yours as the bed is a little different on the 54 model .
"The Journey"
Follow in the DITY
Right. Maybe I'm good. I'll test fit before painting the aprons (was probably going to do that anyway).
Also I am going to measure the height and space behind cab as 52 Carl may be onto something .the truck has been together without the filler panels since I have had the truck I will take a look underneath to see if there would be some wiggle room if I loosened things up and pulled the box back just by looking I would have to go 1/2 to 3/4 inch I will check back later today
"The Journey"
Follow in the DITY
2 Offline
My 1 ton looks like about 1/4 to 3/8 gap, it’s a nice uniform gap, probably just enough so the two never bump together when the cab giggles on the frame when going through rough conditions.
I’ll look for some photos, not near my truck at the moment.
-stan
Thanks for the picture it helps me a lot seeing .I will have to rework my passenger side one as the gap is about half inch the repo is about 3/4 inch to long at the top we’re it meets the box from the box to the filler panel I got about a half inch also but that is without the bracket on ,so it may change my driver side looks okay but I may want to weld a new piece on as I don’t like the way I welded the hole were the exhaust used to go through
"The Journey"
Follow in the DITY
I purchased replacement filler panels, as the originals did not come with the truck, and had to rework both of them as they were both too long and did not properly follow the cab and rear fender contours. The cab, bed, fenders and running boards were all installed for mock-up when fitting the new filler panels. To be expected when working with aftermarket panels. I have yet to be able to install aftermarket panels on my project without minor to moderate "massaging". Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
Thanks should not be to hard but good to know when the originals were cut up ,looks like if I just redo the curve by the cab corner end it should fit .
"The Journey"
Follow in the DITY
Fox Offline
How are your cab mounts?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Cab mounts have never been replaced ,might be worth replacing them as they don’t look to hard to do .Anyone replace there cab mounts and can advise on how the originals stand up to time .I can see if they are worn the cab could be a little lower affecting the gap around the filler panel
"The Journey"
Follow in the DITY
