0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#13745 07/19/2004 3:28 PM
The distributor in my 49 1/2 ton (216 engine) can't be completely tightened. You can move it both up and down and rotate it, not much, just enough that you can feel it move in your hand. What do I most likely need to replace, the distributor or the vacuum advance/mounting plate that secures it?
#13746 07/19/2004 3:32 PM
Y
Y Offline
Is bolt and nut that holds advance mounting plate to the distributor shank tight?
