10 members (JW51, Woodcmiami, dt235sd, MickeyP, Gdads51, HandyAndy, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,699
#1373712 08/17/2020 1:01 AM
PA OUTLAW
PA OUTLAW
hello all ! Currently finishing rebuilding door glass on 1954 chevy 3100 my problem is vent window . Replaced vent window handle tapped roll pin into handle open &close work handle and pin works out what's wrong what did I do wrong or what am I missing . this sounds like a dumb question THANKS IN ADVANCED !!!!!!!!
Try the next size up on roll pins......if the next size up is to big then take the one you have and drive a small round punch into the roll pin to spread it which will make the it fit tighter in the hole. You may have to round one end off a little to get it started but this will work......I've did it a couple times myself.
Just a word of caution. Use something to back up the handle if you try to spread the pin in the hole, ( I have seen guys snap the shaft off by being overzelous! Also, the easiest way I found to install the roll pins was by using a small pair of channellock style pliers to press them in. John
You cam mash the very end of the pin so that it fits tighter as you complete the last 1/8" of pressing the pin home.
