Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (arustycars639, Hugh63c10, KEVINSKI, Gdads51, Lonnie, 52Carl, Peggy M), 573 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
46 Chevy 1/2 Ton 1929 Model A Phaeton
Can someone tell me what is the correct way to adjust the brakes on my 46 Chevy 1/2 ton. The brakes are stock. There are 2 adjusters for each wheel. One for each brake shoe. I'm guessing that both adjusters should be backed off so the wheel spins freely. Then I should adjust one shoe to the point where the wheel will not turn. Then back off on that adjuster until the wheel spins with slight drag. Then adjust the second adjuster until the wheel can not be turn and then back off on it until the wheel spins with slight drag. This makes sense to me but is this correct?
Former BMW Rider
Former BMW Rider
These should help.
Huck Brake Adjustment
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
thanks HandyAndy. Do you know if the adjustment procedure I explained is correct? Or is there a better way.
Former BMW Rider
Former BMW Rider
I'm sure your procedure would get you there.....
I don't adjust them so tight that the wheel won't spin. While adjusting, I spin the wheel to the front on the front adjuster and toward the rear on the rear adjuster for each wheel. I adjust for a 'good' amount of drag and then loosen for a slight drag. Be sure your parking brake is adjusted correctly too. Click on the link in my previous post for the shop manual instructions.
Andy
Got it. Thanks HandyAndy
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.325s Queries: 15 (0.125s) Memory: 0.6094 MB (Peak: 0.6712 MB) Data Comp: Zlib Server Time: 2025-09-21 23:14:07 UTC
Valid HTML 5 and Valid CSS
