2 members (Shaffer's1950, 1 invisible),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13735 03/11/2003 11:46 PM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | I heard that some 59 chevy panels came with a 283ci V8. Is there a special bellhousing that will let you bolt a 62 or later engine to the origional 3sp? Will a 60s truck bellhousing work with the stock clutch pedal and linkage? Will a granny low truck 4 sp bolt to the stock 235 3sp bellhousing? still trying to figure it out please help if you can. Thanks | | |
#13736 03/12/2003 5:24 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 216, 235 and 261 engines will bolt up to the original bell-housing. There are bell-housings that will allow you to mount the `63 and later inline engines to the tranny you have.(some alteration may be needed on the linkage depending on which housing you use and which clutch you use. The SM420 4-speed tranny will bolt up to the housing you have.
