0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1372746 08/10/2020 6:21 AM
Hi all,
I relocated my gas tank to the rear of my 1950 1/2 ton truck. thIs is under where the spare tire normally goes. It is a top feed mounted tank and I am having starting my truck. I am keeping the mechanical pump and wondering if it is capable of sucking gas from the top of the take vs from the bottom as it was originally?
the new universal tank is a little higher that the fuel pump but it does not seem to get the fuel up.
Does anyone have experience with one of they universal tanks and a mechanical stock 235 engine pumps?
thanks,
skipper
If all your joints are tight, the pump should have no trouble pulling from the top of the tank.
Later pickups ('54 and up) with the tank mounted in the cab had top connections, as well as the larger trucks that had tanks mounted at the frame.
rc356s #1372751 08/10/2020 12:34 PM
Crusing in the Passing Lane
The fuel all comes from the bottom of the tank except when first filled, if the fuel tube does not go almost to the bottom of the tank, no matter where the line comes out of the tank, one cannot get fuel when low.
Factory pump should work fine there, by the way, why are you moving the tank?
Ed
Have you tested the pump for proper vacuum? It should develop at least 10 inches of mercury at idle, back where the fuel line enters the tank.
OK, I will check the pump. I have a metal filter and cannot see if fuel is flowing. I have a small glass filter I may install just to see if it is flowing.
The reason I am relocating the tank is because the cab always had a gas smell (wife did not like). Also, I never liked the gas always making the splashing back and forth sound. Also, I think it may be safer having it in the rear as opposed to having it in the cab? I know it is not original but I made a tank cradle and used existing holes in the frame to mount the cradle. I did not drill any additional holes as to not hack up my truck. Not that there is anything wrong with that but I want to keep my truck semi-original with only safety change .
A vacuum gauge does not need a sight glass.
What type of fitting is there coming out of the tank? If it is a flared fitting, loosen and tighten it several times while watching where the wrench ends up on each tightening sequence to observe a slight increase in degrees turned. This process will avoid over-tightening, while at the same time, causing the flare to make a very secure fit with the female inverted flare fitting.
If it is a clamped-on hose, make sure that the hose is new and is a snug fit before the clamps are tightened.
rc356s #1373076 08/12/2020 12:01 PM
This discussion has moved to the Engine Shop.
