1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | A few weeks back I believe it was justhorsenround or tcleaderman (spelling), was telling us to not get silicon spray on auto paint. A few days before I sprayed a silicon based oil on my 29 Chevrolet. It was painted 40 years ago with Dupont Centarie. Is there a way to neutralize the effect? The hinges on the inside have cracked paint and needs to be touched up. Doc.
| | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | PPG used to make a product called Acryli-Clean Wax remover. I think it was part of their Deltron line. If you applied that 2 or 3 times, you could remove silicone enough to paint over it, but I don't know if it is still made. It was very good stuff.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Thanks Jon, I will check online. Ed
| | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Try duplicolor wax and grease remover. I use it as a wipe down before painting. No issues just make sure it is dry before painting. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If ANYONE uses silicone in my shop I shoot them dead and make their family pay for the bullet! Now on a serious note; use the wax and grease removers as suggested and LOTS of towels. After wiping just a couple square feet the towel will be contaminated enough to cause fish eyes in new paint so save the nearly new towel for projects that require no paint. We get jobs where people have kept the dashes shiny and supple with Armorall and the door hinge pins treated with WD40. Huge No No's that have to be cleaned outside before allowed into shop. Silicone has many good uses but NOT around paint.
Evan
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Any good wax and grease remover will work. Mineral Spirits from the hardware store will work just fine. Getting it on paint will not hurt the existing paint but will cause LOTS of headaches if you every shoot new paint over the contamination. Google "fisheyes". If you're planning to refinish any panel use wax and grease remover BEFORE you do any sanding. If there's wax or silicone on the paint, sanding can drive it into the sanding scratches and make it impossible to remove short of stripping the contaminated paint.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | A friend of mine many years back that had a Challenger Convertible. As mentioned, years of armor all to keep the top nice had made it's way to the paint. We were trying to lay out tape to add some stripes and the tape would fall off. We used wax and oil remover, lacquer thinner, and about everything we could think of and it would not remove the silicon layer. Mel asked his wife if she had any suggestions and you could see him cringe from embarrassment when she suggested "formula 409" in front of me. Short story long is that Formula 409 did what no other "commercial chemicals" could not do. Tape stuck...Paint stuck... Life was good again. | | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | I went to Votech school for auto body repair in 1990-91. One of the first things they preached was that silicone woipr cause “fisheyes” in a paint job... even the lowest amounts of silicone would cause issues... not sure how it affects mor modern paints, but back then it was effecting eurthane base/clear. Silicone would ruin a paint job. Auto body men hated silicone. | | |
