7 members (LAROKE, Stovebolt48, Tronman, Bwana-Jim, Otto Skorzeny, Lightholder's Dad, 1 invisible),
72
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | I have a 1940 Chevy 1/2 ton front axle in my 1935 Chevy 1 & 1/2 ton truck chassis. I would like to install a shock absorber kit onto my project. Just wondering if a kit exists or if I can just buy the mounts? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | You might want to check with No Limit Engineering. They have shock mounts for 47 and later which were easy to modify for my 46. George | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | If your going to use the original lever arm shocks they used a steel plate that was held to the front axle by the spring perch U bolts. I have a template if you want to make them out of flat plate. They are a copy of my 35 1.5 ton trucks.
34 & 35 trucks are the greatest
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got a couple of tube shock mounts made by Classic Performance Parts, if your interested. These are not stock type mounts but will work nicely. Let me know if you are interested. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | Thanks for all the info! I placed an order for the kit from no limit engineering. It looks like a good product and I hope if works well for my application. | | |
