1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1372189 08/05/2020 3:12 PM
Hello,
after I got the engine running by fix the distributor the engine runs very high.
How I have to adjust the idle and how much shoult it have?
One another question. If i pull the throttle the accelerator goes down but it want stay in position. The throttle goes back into the initial position. What must I do that it works?
The carburetor I have is this one: https://www.rockauto.com/de/moreinfo.php?pk=1126567&cc=1487579&jsn=406
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Sound like you need to inspect & lube linkage & hand throttle cable, make sure nothing is binding & holding it off idle.
BC
1960 C60 pasture art
I would start at the gas pedal, and trace the whole linkage to the carburetor, making sure each piece is rotating correctly and that nothing is rusted or corroded, making the whole linkage hang up. I would also look at the throttle shaft at the base of the carburetor and make sure it operates smoothly.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Moderator, Electrical Bay
Hallo Wolfgang. Please also make certain you have the spring which pulls the throttle back down. It should be about the same strength as a screen door spring.
~ Jon
