| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 31 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 31 | Has anyone else ordered the parking brake cables from Jim Carter's and found that they appear to have the wrong end attached at the brake side? The originals had a clevis type attachment (which was just sitting in the brake freely since there were no hooks or "levers" to attach to) while these new ones simply have a steel ball at the end.
If someone has come across this as well, were you able to make it function somehow on your truck? | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | There is a parking brake cable clip, Jim Carter part number ME168, that fits on the brake shoe end of the cable. They say it fits the 1-Ton but I had to modify the one I bought from them several years ago and was never happy with the result. I ended up finding an original clip that fit just fine. The armored section of the cable was the wrong diameter and couldn't be fixed tightly to the frame mounted bracket without more fiddling.
A couple of years ago Jim Carter said they had a new design cable that fixed these problems. It was a limited run and I don't know if you have the newer design or they had to go back to the old manufacturer. Eventually I got lucky and found 2 NORS cables on eBay that fit perfectly. Talking with the guy I got them from, he said they were the only 2 he had.
Sounds like you need to talk with Jim Carter---they are very helpful when you call. | | | | | Joined: Sep 2018 Posts: 31 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 31 | Thanks for the reply. I figured out they do have the clevis piece that attaches to the ball end. However, as stated in previous posts from years past, the actual levers they attach to can only be had from a scrapyard so far.
Thanks again! | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Can you post a photo of the levers? | | | | | Joined: Apr 2007 Posts: 3 Moderated | | Moderated Joined: Apr 2007 Posts: 3 | SEARCHED FROM HI TO LOW FOR EBRAKE CABLES TO FIT A 1954 3800 WITH DUAL REAR WHEELS & 14" DRUM BRAKES. SEVERAL PLACES SAID THEY DID NOT LIST THEM BUT HAD THE NECESSARY INFORMATION TO MAKE THEM UP. ANYWAY, I WENT AHEAD AND SEND THEM A COUPLE OF OLD SAMPLES.
LONG STORY SHORT, THREE CABLE PAIRS I BOUGHT FROM DIFFERENT PLACES WERE CRAFTED PIECES OF SOUR CACA. CABLE PAIRS FROM THE SAME COMPANY DID NOT EVEN MATCH ONE ANOTHER. MOST OF THE PROBLEMS HAD TO DO WITH THE OVERALL CABLE LENGTH, ARMOR CONSTRUCTION, ARMOR DIAMETER AND WORK QUALITY. GOT MY MONEY BACK EACH TIME AFTER MANY EMAILS & PHOTOS OF DEFECTS.
AFTER THREE YEARS, I FINALLY ENDED UP FINDING A PAIR OF NOS CABLES ON EBAY. THE CABLES WERE INSTALLED AND FIT LIKE THE BALLS IN A BRAND NEW BEARING. SIMULATED LOAD TESTING HAS BEEN COMPLETED. ALL IS GOOD.
HOPE YOU SOLVE YOUR PROBLEM. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Turn off your caps lock please.
