2 members (Gdads51, UtahYork), 113 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
Apprentice
Apprentice
1 Offline
I bought a 350 engine with a Holly carb to install in my 56 pick up. The carb has a vacume secondaries. I need vacume to power brake booster, 350 trans modulater,and vacume advance distributer.
There are 3/8 dia vacume ports in the runner of the manifold and in the carb base plate. There also is a 3/16 dia port in the metering block of the carb. A hose is attached from the area of the electric choke to the intake throat of the carb above the trottle plates. Can you tell me what hooks to what?
Thanks in advance
here is a link to holley carb instruction manual
hope it helps
mac
http://www.holley.com/data/Products/Technical/199R7948-5.pdf
1 Offline
The port on the metering block is ported vacume, the advance on the distributor connects to there. Any ports on the base plate are manifold vacume, the modulator and brake booster connect there.
Sean
doing what you love is happiness
loving what you do is freedom
There are vacuum ports above and below the venturi. This means one can have both high and low vacuum at idle and cruising rpm's.
I reread you post. My Holley does not have a vacuum hose attached to electric choke housing, so you must be looking at the distributor vacuum line like 1969c10 said.
Riding in the Passing Lane
Use a 3/8 outlet for the power brakes. The manifold one is best. Hook the modulator to a 1/4 in. tube in the lower part of the carb. The dist. hooks to the 3/16 tube on the side of the meterring block. The tube from the choke is to draw filtered air to the choke. It gets it,s vacuum through a passage in the carb.
1972 Chevy c10 Cheyenne Super
