8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 5 New Guy | | New Guy Joined: May 2019 Posts: 5 | I searched the forums, and found similar discussions, but I want to know how wide of a wheel is possible that won’t interfere with tie rod ends on stock 1960 K10 4wd axels. Wanted to go wide aluminum slots until I found two more original steel 3-clip rims. The truck isn’t in my garage yet otherwise I’d try and figure it out looking underneath. Love to hear any other early k10 peeps experiences.
Much appreciated !
Be A Champion Every Day
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 70's GM Rally wheels will work and look nice. 15" and I believe they are 8" wide.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2019 Posts: 5 New Guy | | New Guy Joined: May 2019 Posts: 5 | Thanks! Have you used them with success? 8” rim doesn’t interfere with tie rod ends?
