3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
hi guys was wondering if any of you guys have ever seen or heard of this . My truck has a split drive shaft with a what im calling a overdrive box .
On the dash between the choke and throttle there is a black knob . Going down the road ill push in the clutch and pull the knob out and it drops almost like in to another gear . 1953 3600 235 long bed . like to hear your thoughts . thanks
Truckstell "Tip-toe-matic" overdrive
I have a complete assembly in a storage shed (waiting to go to a Stovebolt.com member).
We have not found a convenient occasion to make the "hand-off"
Truckstell made a similar setup for Ford- - - -as far back as the 1920's. I had a friend with a Model TT fire truck with a Truckstell system, but I believe it was an "underdrive" that allowed the driver to select a very low ratio starting gear to get the rig moving. Since the T model only had two speeds, the ability to gear down in both first and direct drive allowed coach builders to exceed the designed gross weight for commercial vehicles.
post some pics
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
Need a picture as Fred Hone also made an in driveshaft overdrive unit. Believe it was called a Hone-o-Drive. Friend had one in his later (70's ?) Ford pickup that bolted to the pinion snout. The Hone unit was round.
Evan
