| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 4 New Guy | | New Guy Joined: Mar 2020 Posts: 4 | hi guys was wondering if any of you guys have ever seen or heard of this . My truck has a split drive shaft with a what im calling a overdrive box . On the dash between the choke and throttle there is a black knob . Going down the road ill push in the clutch and pull the knob out and it drops almost like in to another gear . 1953 3600 235 long bed . like to hear your thoughts . thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Truckstell "Tip-toe-matic" overdriveI have a complete assembly in a storage shed (waiting to go to a Stovebolt.com member). We have not found a convenient occasion to make the "hand-off" | | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | Truckstell made a similar setup for Ford- - - -as far back as the 1920's. I had a friend with a Model TT fire truck with a Truckstell system, but I believe it was an "underdrive" that allowed the driver to select a very low ratio starting gear to get the rig moving. Since the T model only had two speeds, the ability to gear down in both first and direct drive allowed coach builders to exceed the designed gross weight for commercial vehicles. Jerry
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 |
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Need a picture as Fred Hone also made an in driveshaft overdrive unit. Believe it was called a Hone-o-Drive. Friend had one in his later (70's ?) Ford pickup that bolted to the pinion snout. The Hone unit was round.
Evan
