| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | My truck is a 1953 3100 pick up. It has the 4 speed transmission with floor gearshift. When pulling the engine out of the vehicle I was having a difficult time getting the engine and tranny out as one unit even after removing the transmission support cross-member. I eventually just unbolted the tranny and dropped it separately and the engine came right out. I would like to install the transmission on the engine and put it back in the truck as a unit if possible ,but don`t want a fight getting it in. From what information I have found so far it looks like the three speed engine and trannys go right in no problem,anyone have advise on the 4 speed?
1953 3100 Pu
| | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | You might be able to get the engine/trans assembly installed together if you take the top cover off the transmission, but it's much simpler to install the engine and bellhousing as a unit and then put the transmission in. An engine lift through an open door or a 4 X 4 timber across both window openings and a cable come-along makes it a simple job to lift it into place. Removing the crossmember was a huge mistake, as it allows the frame rails to spread out. The crossmember is a structural brace for the rear spring mounts. Jerry
| | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | Thank you. I will get that transmission brace re-bolted back in pronto!
1953 3100 Pu
| | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I think there might be a misunderstanding on which crossmember you're each talking about. Removing the one rear of the transmission that's bolted to the frame shouldn't be a problem. There's been a lot of discussion in the forums that many trucks don't even have those crossmembers, and a belief by many they're not needed.
Greg Brown
| | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | Some people try to remove the crossmember where the rear motor mounts attach, which is riveted in. That's the one that allows the frame to distort. Removing the one further back that's bolted in is not a problem. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | GM/Chevrolet-Truck considered that cross-member at the rear of the transmission to be necessary up through the 1953 light (3100) trucks (for all transmissions)
The cross-member at the rear of the engine was changed in 1954 Chevrolet Light Trucks. That change allowed the elimination of a transmission rear-cross member in 1954, except with the Hydra-Matic transmission option. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I installed my 261 first and then used a transmission jack with pitch-yaw-roll adjustments. It was super easy, even for me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | With the above, it's way too easy to first install the motor and then the gearbox. I use a engine hoist thru the passenger door, bolted to the top of the gearbox to raise or lower it, from/to the floor.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | We talked about that last year and decided that trucks up to including 53 with enclosed driveshaft (3100) had the rear crossmember from the factory, open driveshafts ie 3600 and above didn't.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
