2 members (TUTS 59, Ponchogl), 106 guests, and 2 robots.
Topics128,035
Posts1,055,564
#1370352 07/23/2020 6:21 PM
Has anyone put a power brake master cyl kit on there 49-54 pickup. i'm looking for a bolt on kit that maybe uses the same peddle but if it comes with a peddle that ok. i'm not going to discs just the drums its a 52 GMC 3spd model any ideas?
Jay D.
jay d #1370372 07/23/2020 8:13 PM
I just finished installing one, could not find one that uses the stock pedals, and worse none that would allow me to keep the clutch (intended for an auto conversion, or a universal hydraulic setup). I would have gladly paid a premium for a setup that was done for me already. That said, with the crazy shipping delays resulting from the COVID, I've been avoiding buying Stateside simply because stuff has been taking months to be delivered rather than the usual days/couple weeks, so I didn't call Jim Carters or the other big supply houses.
I ended up taking the available engineered swap bracket and fabricating a new mount for that bracket, looks very clean and it works very well with the stock pedals. Took a few days of measuring, mockups, fabricating and paint but worth it in the end for me - "your mileage may very".
Someone in the distant past had torched my original mount and used some plates to mount a dual reservoir M/C so my above setup is infinitely stronger than that - but to be fair, that original setup worked fine for decades but looked pretty rough and I didn't want the "wrong person" seeing that and wanting "look harder" smile.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
jay d #1370513 07/24/2020 6:13 PM
https://www.classicperform.com/
Many of the Vendor sold kits are the same or similar parts put together by just few suppliers. So don’t be surprised that many of the pictures and descriptions look the same. Drop shipping is common.
Classic performance has Drum brake power master cylinders, Proportion valving And the hardware for the stock pedals, and Stock location.
jay d #1370520 07/24/2020 8:02 PM
It should be possible to simply move the master cylinder and booster back a few inches on the frame and fabricate some longer linkage from the pedal to the booster to accommodate a manual trans application.
