0 members (), 90 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
#1367237 07/01/2020 12:13 AM
I'm just hooking up the vacuum line to my OG windshield wiper motor. The simplest method is to run a T off the brake booster line. I can't imagine that would cause any issues but I thought I'd ask the experts.
1951 Chevy Panel Truck
As long as your brake booster has a working check valve, you should be good to go. That check valve is to allow for the booster to retain its function for one more stop in case the engine stops running. It will do the same thing when the wipers are on, doing their intermittent wiper thing. smile
Thanks Carl. Now that you mention it, I've seen some check valves have T's branching off from them, presumably for other vacuum accessories. Maybe I should try one of those.
Just as an added safety precaution, try adding a vacuum chamber ( tin can or bulb seen on so many vehicles) for a little extra reserve for initial starting or accidental dying in the rain (Murphy's Law), I did that with my 54 (hid it under the dash) and it made a world of difference, just dont get too big of a chamber.
I'll just leave this for the experts.
H Online: Content
A piece of PVC pipe a couple of feet long with caps glued onto both ends and a rubber grommet fitted into one end cap that will accommodate a brake booster check valve makes a good reservoir. Plumb a separate 3/8" or 1/2" vacuum hose to the brake booster and the vacuum trapped in the pipe will allow a couple of brake applications and/or a smooth shift of a 2-speed rear axle after the engine quits. A pipe up to about 4" in diameter fits nicely inside a frame rail under the cab.
Another good trick. Ill keep that 1 in mind.
