1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 35 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 35 | Fun fact.
Offenhauser triple carb intake, does not fit with column shift, and the rods used to adjust the fenders.
So, single carb manifold back on, new carb. Does anyone have photos of a triple carb setup with column shift they'd like to share? It seems like it should fit, maybe I wasn't holding my face the right way.
Thank you for the comments on brakes. If you read through all my posts, you'll note the brake system is all new. The master failed. Happens. When everything worked, trucked stopped just fine. I have the original, the replacement, rebuilt kits, and another new replacement. Shipping stuff to Saskatchewan is a pain, returning items is a bigger pain. I like having spares. I don't like shipping. I really don't like paying duty. | | | | | Joined: Jul 2020 Posts: 35 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 35 | Okay!
Intake is in, 3spd column shift will need to come out, or I’ll need to modify the shift linkages.
Third carb fits, air cleaner won’t. Firewall will need to be clearanced, or an alternative air filter be used.
Support rod removed allows for the 3rd carb to fit.
On to figuring out how to hook up the skinny pedal. | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | I know that a three carb setup sounds really good, but given the obstacles you’ve already encountered, is it really worth it? You’re not going to see much if any power gain on these old Stovebolt's without investing a boat load of money. In my opinion, you would be better off replacing the existing carb with a carter and avoid any future headaches.
If you want to go down this road, posting your issues in the HiPo forum will get more reply’s. Not everybody follows the Project Journals.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
