1 members (MikeE), 70 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1368896 07/13/2020 12:50 PM
Moderated
Moderated
I have a 1956 6cyl 235 engine. Numbers stamped on engine block are F56U 0457575. Do I have solid or hydraulic lifters? or how can I tell?
The U in the code, is that not thrift master for 56? Like a bigger truck?
Mike
MIke, yes, the suffix U was a big truck (series 6000) 235, and designated Loadmaster (vs Thriftmaster).
Gavrin1, the engine would have originally had solid lifters. Good to double check, but as I recall, the '56 235s only had the oil galley drilled to accept hydraulic lifters if they were originally equipped with them (so only passenger car service in '56).
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Pull the pushrod cover and one lifter. If the lifter has a snap ring at the top and a moveable plunger it's hydraulic. That's the only way to be sure- - - - -all the other advice on identification methods you'll get are simply a SWAG (Scientific Wild-Donkey Guess) While the lifter is out, use an inspection mirror and a bright light to look for the big oil passage drilled from front to rear. If it's not there, you won't be able to use hydraulic lifters.
Moderator, Electrical Bay
And if you remove that lifter (no matter what type), wipe the oil off and set it bottom end down on a piece of flat glass or something like a granite counter. If it sits perfectly still, that isn't really a good sign. It tells you the lifter has worn concave at the bottom and this means it won't rotate in the bore as it ought to. In a perfect world it will be slightly convex and will rock around a bit on the glass...and this along with a slight angle grind on the cam is what helps it to rotate and keep from wearing a slot in the bottom of the lifter.
By the way, Jerry...I've never seen a Scientific Wild Donkey. Guess those must be native to Tennessee.
~ Jon
The brand new (New Old Stock) milk can lifters we put into John's 261 last year were perfectly flat on the bottom- - - -I checked them with a straight edge. On later lifters, you're correct- - - -a straight edge such as the back of a new hacksaw blade or a machinist's scale should rock slightly.
There are three categories of advice:
WAG- - - -"Wild "Donkey" Guess
SWAG- - - -Scientific Wild "Donkey" Guess
T-LAR:- - - - -"Thattttt- - - - -lookssssss- - - -abouttttt- - - - -rightttttt"!
Solid lifer on left, hydraulic on right (note the spring clip)
Mike
Most Sealed Power solid lifters have a spring clip- - - -It's just the same hollow lifter body as the hydraulic ones have, with a non-movable pushrod cup retained by the same spring clip as they use on the hydraulic type. There's a small drain hole near the bottom of the lifter base to prevent oil from getting trapped.
That is interesting to know re clip on a sealed power solid lifter. The solid in my photo is a Johnson Lifter and the Hydraulic is GM.
Mike
Hello Garvin 1,
If you are now confused on how to identify a solid or a hydraulic lifter in your 1956 engine,
don't feel bad because you are not the only one.
You were first told:
That is correct.
Then you were told:
That is NOT correct.
If your 1956 engine has solid lifters,
the lifters will NOT have a "Snap Ring" or a Spring Clip".
Here are some pics of lifters for your 1956 engine...
Hydraulic lifter 761
Sealed Power Hydraulic 761
Solid 874
Sealed Power Solid 874
You can also "point to zoom" on the pics to see the difference.
Hopes this helps.
-Tom
1950 Chevy 3100 w/ 1956 235
