7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible),
57
Mod | | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | 1958 Chevy
What lubricant do ya'll recommend to use on the regulators and on the tracks the arms slide in?
I have used regular chassis grease in the past, would something like lithium grease be better?
Thanks for the suggestions.
58' 3200 235 3-speed/OD
| | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Not sure if there is anything made for that specificaly but would try to use something that the oils wont' seperate out of the carriers on, so you don't end up with a drippy mess inside the door. Any doors I've ever had apart seemed to have a thick white grease on those items.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Get a tube of White White Lithium Grease White Lithium Grease is an All-purpose white lubricant for metal-to-metal and metal-to-plastic applications. This lubricant protects against rust, makes surfaces friction-free, and withstands moisture and high heat. Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I would have to go along with Harold. I have used White Lithium grease for years. You can often see the white grease in doors when you remove the panels. I wonder if that is what is used at the factory. I always have a tube of it in the bench. It is surprising how many uses you find for it when you have it available. Jim | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | White Lithium it is then. Thanks for the suggestions!
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Harold, I used white lith. on my 54, I also used dry spray silicon on my felt channels, tell me I'm ok. Doc.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " "dry spray silicon" will most likely ruin future paint jobs."
Do not use silicone "On [near] painted surfaces... the paint sucks up the silicone and makes paint prep ever more onerous than it normally is (if that's possible)! Paint will not stick to silicone, so always minimize overspray when using silicone near painted areas (door hinges, locks, etc.)."
Many years ago, I threw away all silicone-containing spray/lubricants.
If you use those sprays in a spray-painting room/booth, good luck decontaminating. | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | Every glass shop I've been in used dry graphite if the channels needed any lubrication. If the edges of the glass are done correctly, they shouldn't need any. Also...there used to be channels which were made with a nylon strip in the bottom of the channel with dense pile material on the sides. If you can find this in the right size/style, I'd suggest using it. Makes rolling up/down a treat. Graphite is also good for lock cylinders and mixed with Lubriplate.
I agree with Tim about silicone.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " . . . dry graphite if the channels needed any lubrication . . . "  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | White grease works well, however, any grease attracts dust which becomes a wear ingredient, so dry graphite is a better alternate, or a hard wax.
Ed
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Tim, I did not know that, I'm sure that I got over spray on the new outside paint. Other than making a note in the trucks journal is there anything that can get it off the Dupont paint? Ed
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | What would ya'll suggest for the crank gear and the teeth on the arms that raises and lowers the door?
I already installed it with some white lithium on the gears and some for the center of the rollers, but thought it would be good info for the future and other people searching.
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I like to use Never-Seize. White grease can wash off or harden over time. John | | |
