4 members (Gdads51, Hanks custodian, MickeyP, homer52), 114 guests, and 6 robots.
Topics128,089
Posts1,056,137
Members48,435
#1368959 07/13/2020 8:25 PM
I've seen thousands of AD truck cabs, but I've never seen gauge openings like this before. WTH?
1951 Chevy Panel Truck
Seems likely the dash has been modified. Notice there's also no cutout for the radio.
Greg Brown
I thought perhaps that was the case, but if that's been modified then I want the name of the bodyman because those gauge holes are absolutely seamless.
I do not think that is a 47-55st GM truck dash panel (any of the three styles/configurations) on Chevrolet or GMC)?
My guess (and it’s just that) is the dash is not original to the cab. Just what it’s out of I don’t have a clue.🛠
Former Workshop Owner
Maybe a military version?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Professional Novice
Originally Posted by Frank50
Why is it not a modified 47-53 dash?
Because the openings/cutouts do not match?
Sir Searchalot
Sir Searchalot
It is a typical Chevy/GMC dash. I see the "shadow" of the radio cutout patch. The only thing different about the rectangular cutouts is a "kick out" on far left just before the two gauge holes. That is owner modification. Used a portion of the original vertical side as the side of the kick out. The aftermarket dashes don't seem to be like original, although they say they are. There is no separate ash tray cutout. I'm not an AD guy. The gauge holes have had a plate added for some other gauges.
Sir Searchalot
Sir Searchalot
Look carefully behind gauge holes and radio area to see signs of welding, etc. Unless this is just some picture you found.
There are folks who can do that kind of work for sure. Some on here. If he used a radio delete plate, that part was easy. On the gauge holes, it's mostly a flat round plate welded into a hole.
And the rectangular has already been explained.
Pedals have also been modified.
I also see the suspended pedals.
Professional Novice
You want to see some unusual pedals in an A D pickup, look at what the guy in England did to my former 50 3600.
https://www.volkszone.com/VZi/showthread.php?t=1004369#/topics/1004369?page=6
Hopefully the photobucket branded picture is clear enough to see. At least his little blerb is legible enough to read what he did.
(Sorry to high jack the thread). 😎
Professional Novice
J Lucas may be right or, it kinda looks like a 36 Chevy car dash (+-), I believe. Doc. Yup 36 Chevy car dash, small gauges
We modify or replace dashes all the time. It's an easy mod and been doing some of all brands to make the GPS speedometers look factory installed (no longer use cable or electric speedos). Range from mild like a "Frenched" modern radio into an AD pickup:
[img]https://i.postimg.cc/HJgXnSZ4/dan-s-49-002.jpg[/img]
To wild like a complete hand formed dash in a 39 Ford with under dash a/c up in the dash:
[img]https://i.postimg.cc/F14r6Mfx/Mike-s-39-005.jpg[/img]
Or sometimes a 37 Chevy Sedan Delivery gets a 55 Ford dash:
[img]https://i.postimg.cc/cgmLhhcW/37-hood-002.jpg[/img]
[img]https://i.postimg.cc/Jy88FJ0z/37-hood-007.jpg[/img]
Evan
