0 members (), 105 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
Hello All,
I am in a real bind trying to find 2"x 10"x 116" (could be as narrow as 9" if it is clean) white oak planks for the rear bed of my new project... I am trying to match my other 39 (VB) with a 54" wide bed. The new truck will have a 70" wide bed approximately...
Original planks on the (VB) model are 1-3/4" thick and mounted with 5 wear strips with the following dimensions:
1. 8-7/16
2. 8-7/16
3. 8-1/2
4. 8-13/16
5. 8-1/2
6. 8-1/2
The new bed will require 2 extra wear strips and 2 extra 10" planks... If anyone can help with information as to where to source this it would be appreciated. I am located in Florida, thank you.
Philippe Jeanneau
You may need to locate someone with a portable band saw. They can custom cut boards to any dimensions you want. The biggest problem is that you are out of the natural range of white oak so you would need to travel to at least Georgia. Perhaps if you talked to a local cabinet shop, they may know of a source.
Lots more pictures
Crusing in the Passing Lane
There must be someone on here that knows of a sawmill that does that, routinely. Keep posting.
Ed
I would have never expected to be such a huge problem... I am even looking into something called rough cut oak used for tractor trailer beds. I will know something by next Tuesday....
Philippe Jeanneau
It's not a problem, just a challenge.
If your truck is ever going to be sitting outside, especially in your wet and humid climate I think your choice to go with white oak is good. That species is fairly decay resistant and very durable. Avoid red oak, while it is also very durable, it is much less decay resistant. As I stated before, you are located outside of the natural range of white oak so none of the local sawmills in your area are likely to have that species. You may have to have the boards shipped which will add a considerable cost, but can be done. I found this link to a company I bought lumber from long ago in the past. They list 8/4 white oak, but it looks wicked expensive to me. BTW, hardwood lumber goes by quarter measurements so a 8/4 board equals 2 inches thick.
https://www.walllumber.com/premier.asp
Are you certain you need 1.75 inch thick lumber? Seems like it would be overkill and add way too much excess weight. The composite bed (late 1942-43) WW2 Chevy G506 trucks didn't use wood planks that thick, and it was used in a similar configuration as your VB. If memory serves correctly, the G506 used 5/4 (1.25 inch) thick boards.
I live within the natural range of white oak trees and we have a couple of local sawmills that deal with that species. I can hunt for some contact information if you want to go that route.
Happy hunting
Lots more pictures
Hello Paul,
I really appreciate your help here and you're right, it is a challenge of sorts... BTW, if I read the chart right Wall Lumber wants $5.35 per foot for 8/4 lumber, here they want $15.25 per foot, just in case you think that is big money your way...
In fact, I am crawling under my other 39 (VB) to confirm that the cross sills or stringers (as I call them) are made out of 1/8" thick steel, 1.5" tall and 3" wide C channel, sitting over 1/8" small square pieces of metal and the bed planks are 1-3/4" thick...
Now my (VC) truck ex fire truck, had a 500 gallon water tank and the 6 cross sills were white oak instead of metal, 3" wide and 1-3/4" thick... I am on the waiting list with a wood supplier in Ft. Lauderdale to cut a 10" (8/4) white oak plank and get (2x) 73" pieces and (2x) 47" and that will cost about $200 with tax and shop labor... I am wondering if I should cancel the job and just get 3 or 4 pieces of C channel and set up the deck of this one the same way... As much as I like the idea of nice wooden cross sills the price is absolutely ridiculous, and mind you, originally I was going to set up the 6 cross sills, but I will not be carrying any close to that amount of weight... Still, I would like to make it tough. What is your advice here?
Philippe Jeanneau
Wood was used to allow for frame flexing...steel will rip things apart over time. Find a local hard wood that is cheap to buy, cut to size and paint it with POR-15 on all 6 sides, two coats and it will out late you.
Most truck bodies were custom made so there is no right or wrong way to do it, just build it so it meets your needs...don't overthink it! In the end no one will ever question what species of wood you used.
My .02 cents!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Being a woodworker and forester, your next best bet, for a decay and rot resistant specie would be teak. The wood has a density factor of 53 versus 47 for white oak. You could do an internet search for hardwood suppliers in your area. More for than likely they will have white oak or teak. Common home supply and lumber yards have a lower chance of supplying these hardwoods. Just sawed up a bunch of white oak on the Woodmizer mill here in New Hampshire. UPS will only ship 96” lengths.
1946 GMC Project
"Back-in-the-day Restore"
I think I am going to price out the steel first thing tomorrow morning... Teak is beautiful hard wood but, around here is abot $35.00 per foot! I might have to go through a lumber yard or wood supplier for the bed planks since they need to be 116" long... Fastenal could be an option for shipping, but I can see how that would be hard to arrange...
Paul, you mentioned two local sawmills by you besides Wall Lumber... Do you have the info by chance? I will email Wall Lumber for a quote on the planks and see if they would ship to a Fastenal Location by me... Thank you.
Philippe Jeanneau
Yeah... 35.00 is crazy. I’ll bet there are hardwood suppliers in the area. Good luck!
1946 GMC Project
Keep in mind that hardwood lumber is sold by the board foot, not linear foot. 12" x 12" x 1" = one board foot. Sometimes people intermix the two terms so be aware as it can be a considerable difference in cost.
I agree with Tom, around here I contract with a local woodmizer owner to have lumber custom sawn but then again I live in an area that has abundant timber resources. As a point of reference, 2 years ago I had a guy come to my property to cut some white ash logs for me at a cost of 25 cents per board foot with me suppling the logs. As a very rough SWAG, and depending on lumber grade and kiln treatment, a FAS or #1 grade kiln dried white oak board should retail for around 3-5 dollars per board foot.
Try this sawmill, I am not certain that they do small sales but who knows: http://www.gilkeylumber.com/. This company is a bit closer to you: http://tshardwoods.com/
Also, during WW2, Chevrolet had a specification list of suitable lumber species for use in their trucks and nearly every major tree species was on that list. Evidently they were not too picky with wood quality, but then again they were considering the effective life of the vehicle in months not years. Baldwin Piano Company was one of the companies that made wood beds for vehicles during the steel shortage years of late 1942-early 1944.
Paul
Lots more pictures
I can see how mixing the too units of measurement would easily happen if you don't work with it everyday... Thank you, I have contacted both sawmills for a quote, but in the meantime, someone else replied... The Hardwood Store Inc. in Gibsonville, N.C. 8/4 white Oak (S4S) 1.75 x 120" comes out to be $1268 which means $15.85 per board foot... Shipping another $270.00 bringing the total to $1538.00 Very pricey rear deck, but I have no choice...
Now the rest of the challenge means trying to get some steel bed strips that are 120" long... Would anyone know where to go?
Philippe Jeanneau
Buy whatever length is available and weld them together...way cheaper than shipping in oversized bed strips IF you find someone that has them...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B is right about shipping, but if you asked them, I bet Mar-K could whip up some 120" bed strips.
