0 members (),
364
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,162
Posts1,057,042
Members48,463
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
can someone please post pictures of the clutch and brake springs/linkage for a 49 3100 have the manual but want to se spring size. thanks
AD Addict & Tinkerer
Here is the brake spring and connecting rod.
Phil
Moderator, The Engine Shop, Interiors and Project Journals 1952 Chevrolet 3100 , Three on the Tree, 4:11 torque tube
Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
that will help would like to see a picture of one installed and one of the clutch spring. Thank you very much!!
Here's what mine look like. The front ends attach to tabs on the frame. Can't guarantee you they are factory original, but I believe they are.
Greg Brown
Just found another picture of the front ends - before I got things cleaned up.
Greg Brown
Are you trying to identify the springs from a box of parts, or do you actually need to buy them. They are available from Classic parts.
Clutch Spring Brake Spring Brake Spring Rod
Phil
