2 members (Wheelie, Jimmie D),
125
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | Has anybody added a/c to their truck and if so what kit works the slickest or is the most complete?
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I added a "Hot Rod Air" system to my streetrod with a inline 250ci. Under dash vents and contol head was my option as I didn't want to hack up the orginial dash. The real pain was the mounting brackett for the compressor. It mounts on the passenger side above and slightly in front of the dist. My engine had a OEM HEI dist. which took up tons of room in that area. As the streetrod season was approching and my wife doesn't like hot air blowing in her hair I had to modify the store bought bracket to get the compressor higher up. All this interfered with the hot water port on the water pump. I redesigned the outlet barb on the water pump by cutting the orginial barb off, threading the hole and screwing a "V" shaped barb in. The thing went in and the season pasted. But I didn't like the compressor sitting so high on the motor. Over last winter I purchased a small dist. from Mallory, mounted a GM racing coil and again redesgined the mount and heater hose barb, got the compressor down real low and everything looks great.
| | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | I used old air on my 57 . It was a very straightforward install and I never installed a aftermarket ait kit before. | | |
