3 members (Southerntruck, 54farmtruck, klhansen), 333 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Thoughts, comments, advice...
1971 C10 w350
Picked it up with broken neon tube lights, trailer brake control, (keeping?) Boomer stereo and related, aftermarket A R A cruise control with broken switch in signal arm. Have new non cruise lever and stop light. Other that following the wiring and disconnecting it is there anything I need to be aware of?. Never reverse engineered one of these things. Battery neg is disconnected. Would prefer not to toast the rest of it when I hit the key
Wires were all twist connected and wrapped with painter's tape or scotch locked
Thanks!
MC
Just disconnect the power and the ground, that should solve the toast problem. Some of those had a sensor of some sort on the drive shaft, look for that and follow wires back to the unit under the dash. I would assume the wireing to the blinker handle would have a connection on it. disconnect and you should be done.
Tommy
59 apache 1/2t
261 short stepside
I see a mess like that, I just start pulling wires and start over. But, that's just me.
That is not just you, brother.
At issue for me is, how am I going to feel when, down the road, I have a mysterious electrical issue. That Extra Spicy Ragu mess in the way will likely cause an embarrassing public display not suitable for women, children, pets, and some men.
The wires change colors, sometimes three times to different splices. The purple from the ignition switch is cut n spliced twice. One to a pigtail that goes to what looks like an aftermarket relay that goes into the column( with four other wires spliced into who knows so far then to fuse box, one connected to the tach wire and another spliced into the HEI.
I need a drink or two...I'm afraid of I remove all this mess someting..or nothing will work
Ok boys n girls...arrgg!
Cut the wires a few inches back from the splices. Didn't get into them at all. Ignition is hot, Burped the switch and all good. BUT I Have no lights but the cab light, no gauges, no blower nothing....
Fuses good, nothing smoked...
I'm going to have those drinks now! Should I start smoking? Already hot under the collar. WTH?
52Carl this mess started as a foot stuck into the wiring hanging down above the brake pedal. Oh the pain! Why o why?
You know what needs to be done, Mac.
A beer is definitely called for.
So worst case scenario...if I can't get this mess straightened out, any suggestion for a new wiring harness? As in stock(ish), 350, tilt wheel, AC harness? Fuse block is good. Or should I just require every thing individually? Experts? Anyone? Whits end here...nothing I have found online yet makes me jump for joy.
Three fingers n two ice cubes going on!
With any luck you should be able to tell which wires are original and remove the wires which do not appear to be original. If not, I would replace all of the wires with a new harness.
Do a search for a 71 C10 wiring schematic. I see Classic Parts has one in color for five bucks. If you can follow a road map you can do wiring. Other than the cramped positions I always liked doing a rewire or install.
Evan
I think I have all this mess untangled and out. Going to start tracing wires for bad splices, cuts, no ground.
If that doesn't do it...time to get the shovel out and start digging.
Thanks everyone!
oh my... that looks like a fun weekend project.
Another quality post.
Real Trucks Rattle
Yeah about that...got all that removed. Still have a couple of newish relays hanging that are spliced into the main harness somewhere above the steering column. Ignition wires cut or tapped. I'm getting there but lying upside down under the dash with sweat running down is a pain in the seating area...I asked my wife to " hold my beer", she just snorted and questioned my intelligence. Hummm...
Thanks for the chuckle Rusty Rod!
Did you know that the dash insert comes out pretty easily? Just don't yank on it (too hard). I needed to unscrew the speedo cable tho.
Real Trucks Rattle
I did know that Rusty Rod. It would most likely make this a tad easier. I have been trying not to add too much to the different bins of parts and fasteners. The wife has been giving me the " look".
You know how it goes..Thought I would take a break from this and install a cowel trash screen, easy peasy right? Took it all apart cleaned out the dirt, leaves and cottonwood trash. Oh hey, found the A.C. Damper was broke, one washer line was broke, inside the grommet, and one wiper arm lock spring tab was missing. Waiting for parts to but it all back together then back to the wiring. smile
Thanks for all the advice everyone. Believe I have all the extras out, Properly soldered and shrink wrapped the obvious bits together. Since it is all accessible the next step will be to inspect every wire for anything missed it nicked, check grounds, continuity check, and hit the power. Fingers crossed...
Once again, Thanks!
