1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 7 New Guy | | New Guy Joined: Sep 2019 Posts: 7 | I am hoping someone knows what I am getting myself into. I have a 49 Canadian GMC body that will be going on a Chev frame. The Canadian GMCs used Chev engines, which means the front crossmember is the same as a Chev. I want to install a 302 GMC engine which means I will need an American GMC front crossmember. This will be moving the radiator forward the inch and a half to accept the longer GMC engine. What issues will this swap be creating when I go to install the Canadian GMC front sheet metal with the rad in it's new position? Is there a difference in front sheet metal between the Canadian and American GMCs? I am hoping someone out there has been down this road before and has some advice. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GasHog. welcome, what size of truck are we asking about? The largest Canadian Chevrolet trucks, the 17 series (Maple Leaf 3ton) were GMC powered. I am sure there were hundreds of GMC engines swapped into both Chevrolet trucks and cars back in the day. As my experience is with Canadian trucks I have no personal knowledge of the differences in sheet metal between the Canadian and American trucks, I assume there are differences to accommodate the longer GMC engine. Good luck with your project. | | | | | Joined: Sep 2019 Posts: 7 New Guy | | New Guy Joined: Sep 2019 Posts: 7 | Hello Gabster. Good to know someone is listening. The Chev frame that I am using is a 1950, 162 inch wheelbase with 750-20 tires. Doesnt say on the paperwork anything beyond that except serial number. It is an American truck, I picked it up in Oroville WA because it had a perfect pristine frame just the right length as I wanted a 12 foot flatdeck. Perhaps I should have waited to find a GMC, but I wanted to get started putting it together. I have the 302 sitting in the frame, bolted in at the back but the front mount just sitting on a block of wood to let me install transmissions and rear suspension. Its getting a Clark 5 spd and Spicer 5531 from a 53 tandem big truck. I like lots of gears. If the 302 install presents too many issues, may have to go with the 261 that is in my Canadian GMC for now, but would like to see the big 302 under the hood just for the wow factor. I am in Keremeos just south of Penticton, where are located? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GasHog, I am in Rosedale, between Chilliwack and Hope. If you're ever in my neighborhood stop by for a tour of my rust exhibit, it takes a couple of hours. | | | | | Joined: Sep 2019 Posts: 7 New Guy | | New Guy Joined: Sep 2019 Posts: 7 | Want to make a trip to the Old Car Center one of these days for parts and would love to stop by for a tour. Hopefully in a week or two. Whats your number and we will let you know when we are coming. | | | | | Joined: Nov 1995 Posts: 5,740 24601 | | 24601 Joined: Nov 1995 Posts: 5,740 | Gashog -- I'm a little surprised our GMC experts haven't pounced on this one yet. But you are in excellent hands with 3B. Man, I wish I could go tour his rust exhibit. Bring a notebook as you will be learning a lot from him  From what I have read and seen around here, it is not terribly difficult to put a 302 into a Chevy AD truck. I have never done it and have no first hand experience with it, so hopefully one of the guys who have can pop in and walk you through it. I think it is a good upgrade and around here, the hardest part is finding the 302 in the first place. Clark 5-speed (non-overdrive, I presume ...?) and the auxbox ... with a 261 ... hmmm, good thing you like shifting It will certainly keep you ... entertained.  Have fun visiting 3B! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Gashog, with the correct diff. ratio, the 5-speed alone should certainly be adequate without the Brownie, unless you are up for the extra work. A 3.55 or thereabouts ratio should work well, unless you have very large tires, then 4.10 ratio would work.
Ed
| | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Ed, he wrote that he has 162” wheel base, 7.50-20 tires and wants a 12’ flatbed. I would guess it will have a 6.17 ratio.
Professional Novice
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Hi.i can’t answer your questions about Canadian GMC versus American GMC sheetmetal differences. I would venture a guess there is not a significant difference between the fenders, hood, lower apron, and bumper pan (assuming Canadian GMC’s used GMC sheetmetal and not Chevy front clips) (same manufacturing process using same stamping machines).
It would be best however, that your change to a GMC front crossmember would also include the GMC radiator core support, hood latch assembly, radiator cover, and upper cross brace to be consistent with mounting the GMC radiator and front clip reassembly. Consider the GMC lower radiator hose as well. All of these are found through vendors, EBay, and sources here by posting in the Truck Parts Wanted forum.
Dropping in a 302 is no harder than any other Stovebolt engine swap or upgrade.
I hope this helps... I am not an expert by any means, but this reply should get you started in the right direction, and perhaps prompt a more seasoned veteran here to chime in and either find merit in this posting or not. -Tom
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GasHog, I sent you my contact information in a PM | | |
