0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#136632 01/05/2007 8:25 PM
I am still working on the power steering possibility but am also trying to get some information on trying to lower the rear of my 58' by using a set of 2" drop shackles that I picked up from CPP. I would like to lower an additional 1"-2" by removing one or two leaf springs from the bundle. Anyone have an idea of how to get the additional drop or which leaf, leaves to remove from the bundle?
#136633 01/05/2007 11:20 PM
try 2" lowering blocks.
#136634 01/06/2007 12:58 AM
Lowering blocks won't work on a '58, the spring is on the top of the axle, rather than below like the AD body trucks.
You might want to see how it sits with the shackle kit alone before you take out any leaves.
Bill Burmeister
#136635 01/06/2007 4:47 PM
Get new spring perches and move the springs to the bottom of the axle. This will give you about a 4" drop.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#136636 01/07/2007 8:47 PM
If you just take the shortest 2 leafs out (the ones closest to the axle) you'll get the drop of the thickness of the springs, plus a little more due to spring sag. Should be pretty close to what you want.
