7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby), 114 guests, and 3 robots.
Topics128,129
Posts1,056,362
Members48,441
So my 63 had a single hole in the firewall but my 62 has 2. It was a dual resevor one being for the hyd clutch and the other for the brakes. Right now I am planning on running the truck with a 4L80E auto behing the LS1 but at some point I may convert it to a M6 which would require the hyd clutch.
Is there any boosted dual resevor set up aroud that also has the clutch master? I figure I could use that one ad if I ever wanted to run the M6 the clutch master was there.
I also thought about cutting the firewall and welding in a later single hole 2 bolt firewall piece but that kind of defeat the esay M6 swap.
Any ideas?
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
Z
Z Offline
www.mpbrakes.com has what you if you can afford it.
