| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 140 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 140 | I see alot of info on here about the Felpro 7782B gaskets for the 261 engine. What do you guys think about the Mahale brand gaskets? Are they comparable to the Fepro gaskets? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Fel-Pro has been around since at least the 1930's (used to be "Felt Products Co.") How long has the other bunch been making gaskets? I've never heard of them. Jerry
| | | | | Joined: Oct 2014 Posts: 140 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 140 | My bad spelled it wrong it's Mahle. I was looking at rock auto and they show that brand along with Felpro. Just curious. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Mahle is a big name in pistons, oil pumps, etc. for performance applications (as evidenced by stickers on NASCAR cars). They've been around since 1920, founded in Germany, and started out making pistons. I don't think you can go wrong with either Fel-Pro (who started out in 1918, and specializes in gaskets) or Mahle.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I have used Mahle gaskets before with no problems. | | |
