3 members (sron48, TUTS 59, MRMEROTH11), 66 guests, and 1 robot.
Topics128,052
Posts1,055,770
Just assembling the front Huck brakes on my '49 3600 (3/4 ton). MIght be a dumb question, but I'm asking anyway smile I'm seeing conflicting answers to this on "the Google" so figured I better ask before I start doing anything rash.
Normally, I snug the bearings up tight, give them a couple rolls and then back off until I can feel a little play, then tighten to where that just disappears. Has worked for years and I've yet to lose a bearing.
On this '49 I have to back the castle nut off to where there is just a slight bit of play in order to get the cotter pin in. If I tighten to the next notch, then the wheel won't turn (at all). There's fresh grease and lots of it, and the bearings are packed.
I don't like play in a front wheel bearing, an easy fix would be to cut a new slot in the castle nut so I can eliminate that free play; BUT is that freeplay needed (or not harmful) with these OEM roller bearings?
Thanks!
NC3800
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
H Online: Content
Most spindles have two cotter pin holes in them, 90 degrees apart. The 6-slot castle nut only has to be turned less than one flat to align a slot with one hole or the other. It won't hurt to drill another cotter pin hole in the spindle, if yours only has one hole.
Well now I never even thought to look for a second hole - could solve the problem right there.
I take that to mean my first instinct is right though, there should be no free play in that bearing?
Thanks for that tip!
OT Vehicles:
H Online: Content
I prefer to put a slight preload on a roller bearing, particularly if disc brakes are involved. About 40 years ago when disc brakes were the new kid on the block, I attended a seminar by a brake lathe manufacturer on eliminating shudder and chatter on disc brakes. They claimed that any free play in a wheel bearing could cause chatter and vibration during braking. Applying 5-6 ft/lbs. of torque to the spindle nut would eliminate the problem. Drum brakes are a little more forgiving of slack in a wheel bearing.
Thank you sir; makes sense! All good information there and I appreciate it.
OT Vehicles:
Sir Searchalot
Sir Searchalot
Originally Posted by bartamos
There it is! Thanks!
OT Vehicles:
FYI as an update, using that 90 degree hole solved the problem. Got it excatly where it needed to be.
Thanks very much.
NC3800
OT Vehicles:
H Online: Content
"I love it when a plan comes together!"
LOL!
Sir Searchalot
Sir Searchalot
Like I always say, Do it right the first time or do it my way.
Ha ha ha ha ha well, "the plan definitely came together" anyway! Need a Hannibal cigar emoticon
OT Vehicles:
