3 members (Gib70, Woodcmiami, Danielbolt), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I've completed the 14 bolt rear end replacement on my 1950 GMC 250. I replaced the leaf springs, pins and bushings while I was at it. I'm using 76-78 Eldorado calipers on the back so I'll have parking brakes with brackets from Barnes 4WD to mount the calipers. Up front I've installed 75 Blazer calipers with a kit from TMS.
Now that I have 4 wheel discs, I'm looking for a good power master cylinder combination, any suggestions?
1950 GMC 250 Pickup
1965 Mustang Convertible
1972 K5 Blazer
1973 Buick Centurion 455 Convertible
Crusing in the Passing Lane
Corvette with dual disc, foot power, master works.
Ed
Thanks Ed. Will that interfere with a manual transmission? Also, I see some kits with brake pedals, some without
https://www.ebay.com/itm/1947-54-Chevy-Truck-Frame-Mount-Booster-Conversion-Kit-Brake-Pedal-7-Dual/201107335846?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130830%26meid%3Dbb9498876cdf455cb630b53915338219%26pid%3D101195%26rk%3D1%26rkt%3D12%26mehot%3Dag%26sd%3D151875426223%26itm%3D201107335846%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bDemotion&_trksid=p2047675.c101195.m1851
https://www.tuckersparts.com/Spare-Tire-Bolt-Kit.html?cat=1201
1950 GMC 250 Pickup
1972 K5 Blazer
No problem with trans. Manual MC. Easily made flat 90 degree plate in place of original, 14 bolt SF rear w/ TSM adapter to Eldo caliper, Blazer front axle. '47 GMC 1 ton.
Ed
Decided to go with the Corvette disc/disc MC from Tuckers, TSM kit is arriving today.
1950 GMC 250 Pickup
1972 K5 Blazer
Moderated by  Dusty53
