5 members (Gdads51, Otto Skorzeny, MickeyP, dt235sd, JW51), 62 guests, and 1 robot.
Topics128,049
Posts1,055,698
#1365217 06/17/2020 3:44 AM
It had been on FB Market place for a few months so I went and grabbed it tonight,I wish I would have found it a couple years ago since I have put togather a nice 235 for my 37 and too far to turn back so it will go in stock for a future project. Turns over and no water in the oil so I might try to fire up when I get some time.
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I'll bet it'll run like a sewing machine!
1951 Chevy Panel Truck
Moderator, Electrical Bay
Interesting Jeff, I see the prior owner had a Carter YF on it. Once you figure out which model, please let me know.
~ Jon
You are one of those guys that gets it a few minutes or a day before I do. Dang. Doc
i presume since its a truck engine it will have solid lifters and I also presume the flywheel is drilled for a 11? inch clutch so can I use it with a light duty bellhousing.
