3 members (Donf, rfs56trk, 1 invisible), 130 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Hey Everyone!
I ordered an upgraded master cylinder from CPP (see link below) to replace the stock one. When I went to install it, the crossmember at the back of the transmission gets in the way. The kit also came with a manual transmission bracket. Has anyone used this key? Could anyone help walk me through the install? Thank you!
Link to CPP part: https://www.classicperform.com/Store/1960_1972_Chevy_Truck/4756MMK-2.htm
I had the same problem but my crossmember had to go to make room for my new transmissions... Not sure how you could get around it.
Tim
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
1950 Chevy 3100 216 3 Speed.
It will work but I had to replumb the proportioning valve to the side. See the attached pic.
[img]https://www.stovebolt.com/ubbthread...48C96AD-F6C2-4A70-A0E5-B47223085667.jpeg[/img]
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
can you rename the pic above? I believe it should end in jpg as jpeg is not an accepted file type and I really need to see that photo smile
1950 GMC 250 Pickup
1965 Mustang Convertible
1972 K5 Blazer
1973 Buick Centurion 455 Convertible
It opens right up when I click on the provided link.
Let me know if you still can’t open the file and I will repost it.
Darren
Crusing in the Passing Lane
Opens fine for me?
Ed
