| | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Hello all, my panel is just sitting in the shop (and has been for 20 something years) waiting on me to do something with it. I have pondered the conversion to a 4X4, off an on over the years but never wanted to take on such a job. Has anyone here done this type of job? If I remember correctly the drive train needs to come from K20 or K30, 68-72 years because the differentials are not as wide as the square body’s and thus won’t stick out from the fender wells and look like hell.
Just curious about your thoughts, thanks. Rob
..."some gave all, KIA"...
| | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | This is another one of my “different” rigs  1973 El Coolmino, 1970 blazer running gear (Not a frame swap) 383 stroker, turbo 350. Built outside of Salem Oregon, over 30 Years ago. A very proper fab job. I’ve owned it a couple years. [img] https://i.postimg.cc/k43BM5Qg/6-B742158-19-E0-4-E98-B1-FB-8-A94-CF0-A76-A0.jpg[/img]
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Measure your front axle spring perch width. Starting in 55.2 through '91 all the chevy and gmc spring perch widths were 31.5-32".
If I'm not mistaken, the front axlle spring perch width on an AD truck is 26" or something like that because of the taper in the front frame and springs. All that to say, you probably won't find a bolt in Chevy axle unless it's an early NAPCO axle for AD trucks, and those aren't too easy to come by.
I've thought about this swap before for a '52 3100, and I was going to look into the wagoneer dana 44's. They are pretty narrow, and I think they would fit the truck pretty well, but I never went far with that idea, so I don't know how well they would fit.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Thanks ! I’ll be crawling around under it next time I’m at the shop
