2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
Just finished blasting the frame for my '46, it only took 12 years, 2 moves, 3 kids and a pandemic, but whose counting.
Now what do you all recommend for cleaning before primer and paint. I have read and researched, mineral spirits, paint thinner, prepsol, and even soap and water. It will be difficult to get the spirits, thinners and such into all the areas then wipe them back out to clean up the metal. Soap and water sounds like flash rust to me. What have you done to get the metal ready for primer after all of the sanding and blasting?
Do you recommend epoxy or self etching primer?
Information, experience and expertise is always greatly appreciated.
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I may get some flak for suggesting this, but you could blow out the areas you can't reach to wipe down then, use a spray bottle with grease and wax remover in those spots and then use your air blowgun again to dry the grease and wax remover out. I'm assuming it's freshly blasted, so your main issue is getting the media and dust out.
Kevin, Thanks. I have already done the blowout. My question is more about surface cleaning and preparation. What products do or have people used/recommend to get ready for their primer? And what primer, self etch, epoxy, or both do they like to use to get ready for the paint.
back yard wrench turner
I recommend a spray with phosphoric acid and wipe down with paper towels while it is still wet. If it drys before the wipe down, rewet it then wipe down.
I like Master Series Silver for a primer. It was originally designed as a bridge primer. Master Series totally seals the metal and is better than other products on the market. Check You Tube for a comparison.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I've wiped things down with brakleen in the past. This time around, I've picked up some Final Wipe. I had been using SPI for my epoxy primer, but for the current job Tamco Paint In fact, my crew cab repaint is going to be Tamco from the ground up. OEM color. What really sold me is the customer service/support! Completely outstanding!!
BTW, etching primers and epoxy primers do not get along!!
I would clean it with Ospho or similar product.
If you use Ospho like products, the results become the base on which you put your primer. Primer manufacturers usually want bare metal with a certain scratch depth (mechanical bonding) to bond their primer to the metal. Ospho like products don’t provide that.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
The ONLY thing to put on bare metal is EPOXY primer. It is designed exclusively for bare metal and rust prevention. Everything else is inferior.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
