| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 11 Junior Member | | Junior Member Joined: Jul 2006 Posts: 11 | hi,
im trying to figure out what to do about a steering column in my 1/2 ton 55 chevy 2nd series. id like something tilt. im not sure on the shifter, im going to be running a 350 with a turbo 400, so i guess i could go either way (column or floor shifter). if anyone has ideas for a donor car, or any tips i would appreciate it. looking to do this on the cheap, trying to keep to a budget. thanks.
clark | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You are going to have to modify the steering gear. The gear & shaft are one piece. You will have to cut the shaft & install a rag joint or U-joint. The best column to get is a 67-72 tilt, or one from a van up to about the late70,s early 80,s. They have the indicator on top of the column & the ign switch in the dash. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
